remsing
- Daytona Fl
my '00 gots 65,000 mostly autobahn. Cost 980 euro to fix the a/c compressor thuough
What year truck& what sized tires? Gear changes?Semper Fi said:I just hit 91,000 on mine, but I have a question for all of you. When mine was a little baby, 4000 miles, I was hit hard in the front, cut in half and had another front end welded on. The motor is the same one that was in it when it was wrecked. I have put new driveshafts on it because of the lift I'm running, But does my mileage count as being on original equipment?
lowrange2 said:i have an old XJ in the bushs behind my house with 568,702 miles! and a truck in the driveway with 1,204,382 miles on it! It's a peterbuilt tho...
ROBZ95Xj said:Got 192,000 on my 95. Only motor work was waterpump & T-stat. Also got to mention about 10,00 miles ago when the t-stat went i drove it 20 miles home with the temp needle maxed out and all it killed was the waterpump wich was going anyways.
mine is a 2001 with the 4.0L running General grabber AT2's 265/70/16's (31's) with the 3:55,s still in it. Runs great and there are very few times I wish I would have re-geared. so does my mileage count as original being that it was wrecked, cut in half, welded back together, lifted, driveshafts changed, and bigger tires?Zoro said:What year truck& what sized tires? Gear changes?
Uh, sure. But since you're 300,000 miles under the record, I wouldn't be too concerned with if it "counts."Semper Fi said:mine is a 2001 with the 4.0L running General grabber AT2's 265/70/16's (31's) with the 3:55,s still in it. Runs great and there are very few times I wish I would have re-geared. so does my mileage count as original being that it was wrecked, cut in half, welded back together, lifted, driveshafts changed, and bigger tires?
x99j said:well what year and is the motor and trans original?
lowrange2 said:so whats the record so far? I guess mine doesnt count since it not running anymore? ~568,702~
