DurbElites
- Simi Valley
89 xj 2dr 4.0l
recently i flat lobed a comp cam and my buddy gave me his stock cam out of his 95 4.0. my question is does it work? i have read alot online about 87-95 being the same cam is this true i have heard yes and no. and now the problem, after reading all this i installed the cam and matching timing set with chain (all stock) and now when i try to start the jeep the motor sounds like its dragging real bad on the starter doesnt even spin fast enough to start even hooked up to a 200amp jumper box. checked the timing on the distributor and it was correct. next i pulled the plugs to see how fast it would turn the motor and nothing changed came to a hault like a dead battery. is it possible that the cam/crank timing is off? i also noticed that i was getting suction out of the spark plug holes with my finger over them not sure if its cam/crank timing thats out.
