Sounds to me like both TPS sensors are bad, but each one has a different fault and thus a different symptom. There are many bad effects a bad TPS can have and they depend on where in the output signal the TPS has failed and on which side it failed for the AW4 tranny DUAL TPS. One of yours is really bad on the transmmision shift point side of the TPS, thus the very poor, very late shifting, high reving. The other is also bad on the transmission side but is causing very early shifting. I had the very early shifting problem for 3 years, thought at one point something might be wrong with the engine, but it turned out to be the TPS on the TCU side causing early shifting (like yours).
Here is how it works (in your case). If when rotating the TPS the TCU side actualy goes from 0% to 100% of expected signal strength (output voltage back to the TCU) in only 20% of the span, then that 20% of WOT signal acts like 100% WOT on the TCU side and locks the TCU-Transmission in the lower gear until about 4500 rpm, while the other side of the TPS operates the engine Air/Fuel and timing normally.
The other bad TPS is doing the opposite, it is making the TCU - Transmission think that 100% of WOT (Wide Open Throttle) is only 20% of the span, so the transmission is upshifting early at like 1,400 rpm even at WOT which kills the power since peak torque is at 2,400 to 3,000 rpm.
There are several other TPS failure versions that cause other problems like rapid shfting back and forth between 2 gears....surging engine rpms, low, high idles.....
OverTheHillsATTW said:
New question on the subject. I had two TPS sensors to test with. The first one I thought was bad because of 4,500rpm shift points. Now I threw in a different one. I went to read the volts and nothing..but it was 10 minutes after the ignition had been on the ON position. I put the old back on and same thing 4,500 SHIFT and stalling at every stop sign and turn. I put the 2nd one in and it shifts great..the idle even seems close to normal. I get out on the road and pedel to the floor and it's like turtle on my John Deere. I also had to do a TB swap because my butterfly was so off. I've cleaned the ground wires and bought a can of CRC electric cleaner and Grease. A very nice guy at Advance down the road also helped me out by giving me a whole book to borrow on Renix era engines and how they work. I'm just trying to figure out the loss in power. It had tons of power for a 19 year old engine before the shift points happened.
