Locked98GC
- San Diego/IB
1 Check ignition timing and timing advance.
2 Check the knock circuit. (Youtube it)
3 No EGR on 94 4.0 Jeeps. (Skip this step)
4 Fuel octane (Is it old gas in the tank? Regular gas is what is needed, not premium.)
5 Check for high intake air temp. (Sucking air from inside engine compartment?)
6 Check for an overheating engine block. When was the last time coolant was changed, thermostat changed, water pump might be going out, radiator getting plugged, general overall condition of the cooling system. Clutch on the fan included. Need the actual temp of the coolant, gauge could be messed up. 1/2 way seems to high, but I have idiot lights, so don't know if that's right.
7 Carbon buildup (Seafoam should have cleared it but might need a second if it was really bad.)
8 Dirty fuel injectors. There are 2 ways dirty injectors can affect NOx without causing increased levels of HC and CO. (1)Spray pattern which can cause hot spots in the cylinders. (2)When only 1 injector is clogged, the rest of the injectors can keep the HC and CO levels within specs, but the lean cylinder's temp increases. (Have you gone through a whole tank of gas with the injection cleaner in it?)
Need a picture of all the used plugs and cylinder they came from. #2 looks OK for the mileage, but #4 looks way to clean.
Need to fix the problem, not put a Bandaid (cooler plugs and snake oils) on it. (well, maybe to get it to pass smog.)
