Markos
- Seattle, WA
I responded with pics to this thread:
http://www.naxja.org/forum/showthread.php?t=915617
I switched my image host, so the pics are back online (hopefully for good).
Markos said:Thought I would add to this post. I snapped 3 of the 4 rear shock bolts. I tried drilling one for an hour. The bolt drilled with ease but the nut was tough. I ran to the store and bought an air hammer, which removed the welded nuts with ease. There is a lot of mention of fishing bolts through holes in the frame etc, but few pics. Here are a few pics from my recent install.
This is the nut inside the frame. Notice the tack welds. Removed with air hammer:
This is the area on the frame (above the axle) where you fish new bolts through. I could actually fit part of my weak hand on the passenger side. I had to use a socket and extension to fish the bolts through on the passenger side. I used anti-seize on the bolt head to keep it fixed within the socket.
I replaced the standard (edit: grade 10.9) bolts with 13mm (head) bolts and nuts. They are currently smothered with antiseize.
This is what it looks like 'behind the scenes'. Note that there is no way that you could actually see inside the frame in this manner, unless you were using a mirror.
