xjbump
- S.E. Mass, just above the Cape
This is a list of what I have left to get rid of. All parts are for Pre-96 XJs unless otherwise stated. I still have a couple totes of parts to go thru so I'll update as I find more stuff. If you need a pic I should be able to get one and the more you buy the more I discount. All front driveshafts and elec. fans are gone.
Axles/Suspension/Tires/Wheels
2 – D35 Rearends – stock 3.55s – has completely new brake setup $10 & $50
1 – D30 Frontend – stock 3.55s – disco - good joints and calipers $50
1 – 8.25 Rearend – welded 3.55s – from 95’ $50
2 – CJ5 Axles – D27 & D44 Offset – unsure of gears $50 for pair
2 – Ford 9” – Fullsize stock 3.54s – 5 on 5.5 – Not Nodular $150ea
1 – Pr of 2” blocks $10
1 – Steering pump & box w/hoses $30
1 – Steering Shaft $5
3 – Rear Driveshafts – All from AW4s - 2 older style and 1 newer style $10ea
2 – Prs of front coils from a 00’ & 01’ $10pr
Engine/Tranny/Tcases/Accessories
1 – 90’ 4.0 motor $100
2 – Computers from 95’ XJs 1- AW4 & 1- AX15 $50ea
1 – Water Pump $10
2 – Gas tanks and pumps $40
3 – Starters $15
2 – Water Necks w/Temp Sensors $5
3 – T-case Linkage NP231 $5
1 – Coolant Res. Bottle $5
2 – Older style washer bottles $5
2 – Newer style washer bottles $5
2 – A/C Comp. Units $10
1 – Factory Airbox $5
1 – Radiator $20
1 – ABS Booster & Master cylinder 97+ (00’) $25
Exterior/Interior/Elec.
1 – Reargate black $20
8 – Prs of reargate strut arms $10
3 – Hoods – White- paint is good $25, red & blue- paint is bad $10ea
2 – Header Panels w/lights – black $25
1 – Pr of white doors- Drivers has rust on bottom $25
1 – Front bumpers – 1 chrome $10
1 – Rear bumper – black with new brackets $10
1 – Set of F & R bumper brackets $5pr
1 – Pr of Fender Supports w /horn $5
1 – Wiper motor and mechanism for front $15
4 – Prs of Wiper Arms w/blades $5pr
1 – Auto T-handle Shifter $5
3 – Rearview Mirrors $5
2 – Pass. Door Mirrors $5
1 – Drivers Door Mirror $5
2 – Prs of Taillights $10pr
2 – Blower Motors $10ea
1 – Gauge Cluster w/Tach – grey from 94’ has small elec. Plug on back $10
1 – Temp. Selector Switch $5
A ton of Pre96 Dash switches $3ea or 2 for $5
1 – Pr of Air Bags w/sensor unit D & P 97+ (99’) $75
1 – Headlight Switch 97+ $5
1 – Front bumper endcaps and center plastic pieces 97+ $20
1 – Reargate 97+ (01”) – black tinted w/struts $50
2 – Center console trim- Drk Grey 97+ $5
2 – Grills 97+ - 1 Painted Black w/chrome centers $10 & 1 Black $5
1 – Drivers Rear door power window motor & assembly 97+ (00’) $10
1 – Drivers side F & R door handles w/power lock, rods & latch 97+ $10
Misc. Parts
Ford P/U or Bronco radiator $20
TF999 from 86 CJ – no TC or flywheel $50
2 – Airtanks for On board air $10ea
Steering Pump & Box w/hoses and steering shaft from YJ $30
Alternator from a YJ w/4.2- v-groove belt $20
1 – Water Pump $10
3 – Starters $15
1 – Radiator $20
Misc. Parts
