jasonsxj
- centralia mo.
Re: Where you from?
:gonnablow ooook ???Yes. No. Not sure. No, definitely do not bolt in.!!!1
are the spring perches the same ? width??? of axle ?atriot:Wow, I've never even seen some of those names before.
As Starboard was saying, The axles come out of the same vehicle, so yes they are the same bolt pattern, 5x5.5.
The sky is the limit for the shock mounts, as you will either need to make them, or buy some.
A 9" is definitely not bolt in.
well y did that guy said they were ? how about width ? :dunno:
yes it's old thread ! but is the the bolt pattern the same ? and what about shock mount's ? and the width of those 9" axle's ? thanks for any info ?! and it bolt's right in ?? that's what i need!!?? :compwork:
44 came out of a 1978 f150
9" came out of a 1984 f150
9" is not shaved or anything. All I did was clean it up put all new gears, brakes, etc.. and it bolted straight up to my rear leaf pack. I did not have to mod the spring pads or anything. I was very easy and straight forward
Let me know if you have any more questions
Did you keep the shock mounts on the 9" stock too?
could you explain how you cut your own 2lo shift fork?
