winkosmosis
- Maui, Hawaii
ColoradoRaptor said:Hello McFly, ground clearence is achieved by your tires not the lift! The lift allows the fitment of larger tires which in turn moves the axle/diff away from the ground giving you clearence! The lift moves the body/frame away from the drivetrain/axles! It is all about the tires!! Wheeling 101!!:rtm:
That's not true. You can put your wheel over an obstacle so the axle doesn't hit it (that's the point of solid axles), but when the wheel goes down on the other side, you need enough clearance to not have your body hit the obstacle.
