It really looks like both the OP's spacers are on his mount, just that the rearmost one is pushing the bushing into the mount, and is why it can't be seen. If you look at the bushing, it looks like it is getting sucked in.
The word from brown dog is that my engine is way too forward. They advised to look for slotted holes around the crossmember, to move it back, but I did not find any.
I have found in installing the engine mounts I have made that the brackets on the block side vary quite a bit for the different years. I have found it necessary to use spacers on some to keep the bushings in the mount and some were very tight. It's too bad the engine brackets are not all the same.
