godxzilla
- N40°6.11142, W082°51.2472
Thanks everyone! I took some pics so ill post em up. Ill use this info and probably do something this weekend.
Mike
Mike
??? Removed the locks? How do you keep whatever is in your jeep away from casual thieving? I am really curious because a while back, someone tried to pop out the cylinder on mine too. I came out and scared him away i guess ( didn't see him, just heard him) He left me a chipped and bent flathead screwdriver in my driveway as he ran.
So serioulsy, how do you lock up? Or do you just not leave anything in your Jeep?
X2, thats what I always do. But then I have a distributer in my Heep. The shut off switch on the cps would be a easy thing to do.FELIX said:Quick & simple, take the coil wire with you. Takes another minute or 2 but even more secure, take the rotor. Won't start w/o either one & it's free
Rob $.02
scoobyxj said:Yes it will on a 00+
P0320-
No crank referance at PCM-
No reference signal (crankshaft position sensor) detected
during engine cranking.
Also
P0320-
No RPM Signal to PCM (Crankshaft
Position Sensor Signal to JTEC)
A CKP signal has not been detected at the PCM.
There two other codes for high and low voltage conditions on the CKP too.
The NNS-
P1899 (M) P/N Switch Stuck in Park or in Gear Incorrect input state detected for the Park/Neutral switch
(3 or 4-speed auto. trans. only).
Also after reading the FSM a little more. Interupting the the coil side of the ADS relay without interupting the key on referance signal to the PCM will light the MIL too. If you want to run a k run kill switch you will have to interupt the run wire from the iginition switch. FYI interupting the fuel pump control circuit will also light the MIL. You can pull the fuel pump relay though without lighting it. I do it when ever I need to crank the moter over without it starting. Just did it yesterday infact.
Ben H said:Sorry man, but on my 2000, that is the way that I have my kill switch set up. All I did was make a switch with one wire from the CPS. Never got a code and I use it every day. I dont know how you messed this up, but you shouldnt have gotten a code. Try cutting into the other wire. I cut into the 5volt wire, and simply hid a switch in the loop. But using the CPS as a kill switch has been done before, I got the idea from Naxja, and know of at least three people who have the same set up (S.R.A.)
:cheers:
Markos said:Sorry for being so vague. I removed the lock tumblers and replaced them with carriage bolts. I painted them to look like locks at first glance. I rely on the power locks for entry. I haven't run into any problems so far. I keep a spare remote in the truck, which is still accessible by key. I also have a kill switch that I installed. I'm also working on a center console insert from a modified ammo can. I'm going to use one of my two remaining lock tumblers for the center console, that way I'll have the same key as the rear door, ignition, and glove box. Here is a writeup on the carriage bolts, along with a bunch of unrelated drama...
Inexpensive Theft Deterrent (done)
