I reused the Pro-Valve off the Bendix ABS, just uncapped the plugged port and cleaned it all out, actually pretty clean........... I do have the ZJ one that came with the used ZJ booster, so if i ever go to rear discs I can swap that one in.......
I redrilled the brake pedal for the booster rod... Centered the rod in the booster and marked the pedal shaft..... I also drilled the hole off center to raise the pedal height as it seemed a little low for my taste if the hole was in the center of the brake pedal ..... it came out perfect, also my brake light switch works first try using the old abs rod end I cut off and used as a guide on the ZJ brake rod..... Well all buttoned up......
I spent a little time and removed the ABS contoller from under the back seat, the ABS pump and lines..... all I have left are the wheel speed sensors ...just gonna leave the sensors in and cut the wires at the sensors and where they pop through the floor pan under the rear seat to keep the holes plugged up.........
Also got rid of the Anti-lock light and fixed the parking brake indicator light which dont work with the ABS module removed........pretty simple..........
I pulled what is called the yellow abs light relay...... Mine was right under the resistor for the fuel pump............
that turned off the Anti-lock light....pulling the 2 amp fuse in the fuse box for the ABS dont do nothing I could see..... left it in.....
And to get a working brake light indicator on the dash when you pull the ebrake all I had to do was go to the larger ABS controller connector under the rear seat and use a scotch-lock to tie C5 wire to C9 wire together..... one is blue wire and the other green...... walla, working e-brake indicator light...... also I hooked up the switch to the pro-valve..... uses the stock plug, just had to make the wires a bit longer....... in the ABS book the pro-valve switch is called a DPA switch...... it ties into the red brake light indicator also along with the ebrake like a non-abs system...... so have that working also........
All in all the conversion was pretty easy...just takes a little time with small details..... also got the stock windshield washer bottle to fit in the stock location...... took the heat gun to the part that hit the booster...... got it nice and hot and flexible, installed it hot and it molded itself around the booster.......pushed it against the booster passed the mounting holes, let it cool while pressing against the booster.....that gave me a little clearence between the bottle and booster....... it took me longer to get wires and hose to the rear pump run and postioned right....lol........
Will test drive tomorrow when the weather is a bit better......friggin raining and cold last few days........ anything below 70 degrees is cold! living in the Arizona desert has made my blood thin
