Jeepguy03
- Connecticut
So I recently had an alignment done on my 2000 XJ. The shop test drove it and said it has a brake pull to the driver's side. I knew this, but it seems to be getting a bit more noticeable so time to change the caliper. I'm thinking if it was a hose that would make the caliper drag, and the brakes don't seem to be dragging. I only have the pull when applying the brakes.
What brands are decent for rebuilt calipers? Should I change both at the same time? My brakes are in otherwise great shape. Would it be worth upgrading to braided steel brake lines up front?
