JeepFreak21
- Cameron Park, CA
evil dead said:
One of my all time favorite builds...PERIOD!
Same here!
Billy
Those rocks are getting smarter and smarter.vetteboy said:Better watch out for those protractor-carrying rocks... :wierd:
In NJ my street-legality is mostly determined by a maximum height of the door edge from the ground. I'm at the maximum right now.
If I wanted a trailer-only rig, I probably would have done it differently. I probably wouldn't have used an XJ at all.
JeepFreak21 said:Doors... yes. Windows... maybe. Stock lower door hinge... no way.
Billy
http://www.pirate4x4.com/forum/showthread.php?t=614554&highlight=wyocrawlerJeep9717 said:Thats puurdy, anyone know the specs?
Billy
Ya, I wish I could have bought it. :tears:oo7ravisXJ said:finally sold, thats a lucky guy
Phil said:Wouldn't that be "ruler-carrying rocks"?
If you cant make your rocker over about 40 degress.... then its not a boatside
Zebaru said:My bottom hinge is totally gone. Well, the place where my bottom hinge would be if I had doors anyway...
With my cage, figuring out functional door has been a real PITA - which is why I have none... However, with stock door jambs mostly intact, a clever person could raise the lower hinge point a couple inches, rework the bottom of the door, and still keep it functional. Watertight would be more work, so I would suggest trying to use the original bottom of the door and top of the rocker (like 'sectioning' your door if you will...)
The windows would definitely not fully roll down - think back windows on most small 4-door cars...
polar_jeep_04 said:anyone know the specs on this one?
Phil said:If you can have doors you can have windows. That doesn't mean they can roll down, though.
JeepFreak21 said:I looked into it at one point. Raising the lower hinge would be a MAJOR PITA. The window only goes down to the first body line on the door. The mechanism goes a little farther, but could probably be reworked. If your boatsides started at that first body line (from the bottom of the door up), you'd gain 6-8" and your window may still roll down all the way.
Billy
Zebaru said:I hacked apart doors with power windows, and that mechanism pretty much goes to the botttom, which is why I said they wouldnt fully roll down - but I guess I hadn't considered manual cranks for some reason...
One problem with cutting at the first body line, and still trying to keep the original door bottom sealing system intact, is that your new door bottom is an inch or so above that line.
I have the inside door frames leftover from my skins, maybe if I get bored one day I will do some mock-up to see what is possible...
