sixty7ss
- Gilbert, AZ
The A/C blower motor has stopped working and I'm 90% sure it is due to a connection problem between the blower motor and wiring harness. I used to be able to fix the problem by wiggling the connector and pressing it in. That doesn't work anymore. I can't get the connector off to check it. Is there a trick to that?
Has anyone else had this problem? What did you do to fix it?
I tried searching and found a ton of stuff about relays and fuses and switches, but haven't found anything about the connection.
