MudDawg
NAXJA Member #728
- Central Florida
Gimmicky trick double throwdown wierdo plugs are sold for one reason...to try to hook you into buying them...they WILL NOT work better than a standard plug...they will in a lot of cases make the motor run worse. I like NGK...any major brand will work...single electrode plats are fine....iridium is not needed unless you run boosted (they won't melt easy)...
