Thunderhead7
- Tucson, AZ
Interesting Mods, thanks for posting!! Any more shock mount Mods out there? Thanks.
Mine is almost exactly the same, but I bought the mounts from JKS. Ruff Stuff makes a nice double shear shock bracket that is high clearance.
If I did it again, would probably get RS since they are so much cheaper and double shear. Haven't had a problem with the JKS yet though. Just remember to get shorter body shocks because this raises the mount quite a bit.
http://jeepinoutfitters.com/scripts/prodView.asp?idproduct=397
http://www.ruffstuffspecialties.com/catalog/SBSIDEMT.html
Thanks man. I really should have started a build thread back in the day, but I had NO idea my Jeep would end up like this haha.
Like I said, absolutely nothing wrong with the JKS mounts and they are actually a seriously nice part. The RS mounts weld to the tube just the same, but instead of having a bolt sticking out, you have two plates parallel to the axle with bolt holes. The nut goes right up against the axle tube and the shock eye goes in between the plates so you can run a bolt through both of them. Double shear is always a stronger solution, but really not totally necessary. These require a tad more welding, but are also cheaper.
Why are you worried how they look installed? The basic premise is simply put shock mounts on that don't hand 4" below the axle. It's much more basic than you are making it...Thanks for the links to both systems, can you post up some photos of how the RS mounts look installed? Thanks again.
Thanks! The pic they show of it doesn't give you any sense of scale. Now I'm thinking this is definitely the way to go. I'm also curious about the JKS crossover shock mount. I need to do some more research/searching on that thing. I'm not convinced of the benefits they're trying to sell but I'm not mechanical engineer.
I don't have the RS mounts, but they are a great design. And I am a mechanical engineer
The comment I made about not being a mechanical engineer was in regard to the JKS cross-over shock mount and the selling points JKS makes. My RS mounts have been ordered :cheers:
They're welded in the stock location, but don't hang as far down. I have no idea what my mounts are, I bought the axle prebuilt from another member.I agree, I'm a visual learner, so it helps me to see where exactly these are welded to the axle. Thanks. I would still like to see photos with the JKS install. I am already sold of the design. I just ordered a set.
I'm having a hard time visualizing what the RS kit looks like mounted. I've been admiring your build for some time now as it pretty much lines up with what I would like to do. I was set on the JKS mounts but now?
Sent from my DROID3 using Tapatalk
