rocklandxjer
- North Rockland, NY
Wow. It's been a heck of a long time since I've posted here.
I've got a simple question that I hope one of you guys can help me with. Recently, while tightening the belt on my 94 [XJ] I found myself cursing the jeep gods once again. The bolt that rotates the steering pump pulley broke off in the "nut-receptacle-thing" that it threads into.
I believe I can remove the portion of the bolt that is still threaded in [the bolt broke off right at the opening of the nut] But I need to find myself a new bolt. The one used is a "semi" lag bolt, the smooth portion only extends about a centimeter [so that is spins neatly to push/pull the pulley] and I believe that it is 10mm thread, but I can't be sure. Would a 10mm bolt of comprable length work, or is the bolt somehow specific. That is, do I have to order a new one, or will a replacement hardware store bolt suffice?
Thanks for the help guys.
Travis
Travis
