Cottontail
Three-De Off-Road
- Nashville, TN
Updated the list:
new u-joint in front drive shaft - DONE
new driveshaft straps - DONE
new front pinion yoke - DONE
repair spring holder on drivers side DONE
repair snapped off bolt in the differential housing -DONE
Replace fluid in rear axle DONE
Repair broken track bar DONE
Get one new 31" MT DONE
Pick up spare long shaft DONE
Pick up spare short shaft DONE
Route cowl air induction system DONE
Mount new spare on factory rim
New negative battery cable
New ball joints
New tie rod to pitman arm
New tie rod to left steering knuckle
New tie rod end at the left steering knuckle
Replace Durango steering box with OEM (Maybe - if the new steering doesn't fix what needs fixin')
Replace front skid plate
Oil change
Install some hockey pucks
New ball joints
Oil change
