I seem to have a short somewhere that is causing my battery to go dead every couple of days while my xj sits in the garage. I have pulled fuses to try and isolated it with no luck. The way that I know there is a draw on the battery is that when I hook up a charger to the battery, I get a strong spark when hooking up the ground lead of the charger. It will also spark when I touch the body area around the battery. This is telling me that I probably have a bare wire touching the body somewhere. Am I assuming correctly?
Anyone have any ideas? I've looked all over but can't seem to find a wire that is tight or seems to be worn.
Thanks
GRNT
Thanks
GRNT
