jneary
- springfield, virginia
its usually 20- 25 milliamps. make sure the glove box light , rear cargo lamp or sun visor lamps arent staying on
Geekstarrs test is a good one, although I like to use a multimeter set on milliamp scale, instead of a test light. Then pull fuses until you find the right circuit with the draw.
I think you'll find a constant 6 mA draw, that is constant no matter what you disconnect (although 30 mA is indeed excessive). It's caused from the ECU being powered with the key off. It's not enough to be concerned with, unless the XJ sits for an extended period.
If you have a courtesy light above the passenger side visor, make sure it's actually turning off. Also underhood light, if you have one.....a 30 mA draw is about right for a small bulb being on somewhere.....
A CB turned off shouldn't draw anything (no memory does it), but you can check it with your meter. When my battery is on it's last legs, I have to start it every couple of days. But for the first 2 years or more after it's new, it's good for at least 3 weeks.
5.5 amps off is way too high, should be in the milliamp range as stated earlier. Some meters display the -1 when they are out of range, usually indicating too much of whatever you are measuring.
You can also disconnect one of the cable to make sure that the drain is not internal to the battery with a bad cell, although that should show up if you get the autoparts store to test it.
