Talyn
- Radford, Communistwealth of Virginia
XJCHUCK72 said:The length is exactly what I'm talking about. At that hieght just over 3", also you have the spacers, I'm not saying they are bad, but when your axle isn't centered over the spring mounts may be causing your wooble. I know when I was at 3" adding longer LCA's made my XJ more stable. You have done a really good analysis, I'm thinking either there was an accident or your at the point for LCA's. Your caster will change, if your worried get UCA's to boot. Go to the classifieds for cheap used stuff.
So you are saying that the extra 1/4" of an inch (by removing spacers from behind the LCAs) or so the aftermarket LCAs will give may help? I have the caster turned up by adding spacers behind the LCA brackets. If I put in aftermarket LCAs I will be keeping the caster the same because if I put my caster any higher my pinion will have issues with the angle on the drive shaft. The only way I would be to push the axle forward anymore would be to get aftermarket UCAs... but all the tables I have seen regarding UCA length at a certain lift height have shown it to be very small over stock measurement.. like 1/8" small.
If I had just paid to get my '91 XJ fixed from the accident.. ugh
-Chris
