hey all new here. I have an important question. I've had a broken motor mount for a while and decided i ws going to change it today. so i loosened the main bolt, put a block of wood on a jack, lifted the engine, and took off the top and bottom nut. after that i removed the oil filter hoping i could clear the extension piece with the bolt. No Go. After putting everything back in place i tighted up all the bolts and then let the jack down, noticing how high i had it jacked. well i went for a drive and holy sh*t the thing is vibrating so bad i can hardly drive it. Loosened up the main bolt and it was ok for about a block and then the same. Anyone know what i can do untill i get a chance to fix it. Oh yeah and is there a gasket in the extension piece that goes to the oil filter??
87 4.0 auto
87 4.0 auto
