I can't stand bringing up old threads, BUT...
After searching and searching, this is the thread that got my Jeep fixed!!!
My symptoms were:
Backfiring through the airbox.
It would only DRIVE decent when giving it a HAIR bit of throttle on a level road.
I would have to MASH the pedal to the floor to move up ANY sort of hill. Otherwise, it would spit, sputter, backfire(through the airbox).
Idles pretty well perfect.
When starting, it would crank for longer than usual.
I started with replacing the O2 sensor, then a fuel filter, then a FULL tune up, cleaned the IAC and throttle body, then adjust the TPS, sea foam through the oil, gas AND vacuum lines. Of course, none of that fixed my problem.
Found quite a few threads on other forums with the same EXACT problem as me, but the threads just died leaving me with no help. THANK YOU ALL for keeping up with this thread!!!
I replaced the fuel pump and MY GOD, the little "filter" on my old fuel pump was BLACK. I don't know if I would've just replaced that part if that would have helped, but I figured a new fuel pump couldn't hurt and I couldn't be happier!!!
Thanks again!!!
-Mike-
