My 8.25 should cost me about $300-325 with new full rebuild kit/bearings and seals.
Lincoln locker done. 29 spline...all set.
Disc brake kit...junk yard steal like $75 at the time.
I only need 4.56 at max In My Opinion. At least for now.
I thought I read the 8.25 had stronger tubes and the shafts are the same size until it necks down at the spline.
Running discs means the c-clip isn't an issue.
Lets recap..$300-325 for a fully built axle DONE....OR
Start with $400 for a chunk of iron and start building to the tune of $700-1500 depending on your choices.
For that coin...I would go 9" or D60. Go 5x5.5 pattern and do a D44 front with 9"rear if your going for the big spender stuff.
goatman..its not a matter of wanting to argue...Its simply a matter of seeing the same junk from 6 months ago at $150 going for $400 FIRM!!!!!!!!!! listed by a jackass in a forsale section of some forums. Like they have the mother load of gold at their fingers...give me a freakin break.
I have seen some damn good wheelin rigs that looked like the guy spent $500 to build it.
Then lets see...Me being in the wrong sport I think you said...I think I have $35,000 in to my CJ7 and its not done yet.
My XJ is the low buck ride and it runs...well it will next week when the stroker is started.
So before you think of me as SON or BOY...I might be a bit older than you think
