So I swapped my aw4 to an AX15 in my 92 4.0 xj last weekend and had zero problems during the swap. Brand new Luk replacement kit (pressure plate, clutch disk, and throw out bearing) installed as well. It shifts going up in gears no problem but I am having a hard time down shifting from 5th to 4th and from 4th to 3rd. Ive even tried shifting into neutral first then clutching again into the gear down, Just a bit too much grinding for me to push through. BTW this tranny has new redline mt90 fluid as well. When the conversion was completed the clutch pedal was pretty soft but after a lot of bleeding and just driving it has gotten more firm. I believe that maybe I am not getting enough clutch disengagement for the down shift? Does this make sense?
Anyone else have a problem downshifting?
TIA
Nick
TIA
Nick
