bajacalal
- San Diego (North County), California
So I'm helping my roommate swap his engine and transmission into another XJ from one he rolled. We both have/had 96'es 4wd with a 4.0 and AX-15.
How much play is there supposed to be in the input shaft?
We pulled the engine and transmission apart (he thinks the input shaft seal is leaking) and you can move the input shaft about 1/16" in any direction from center.
Is the bearing bad? On the other hand, I don't see much of a leak.
