Speaking of this - has anyone figured out how to change the LEDs in the window lift switches? I haven't looked at it yet - is it a removable part or do you need to replace the whole switch with a red one?
yeah, the vac gauge is almost more useful (sometimes) than the tach...
vac gauge install-
pretty easy
it comes with most of the fittings and sensor tube, i believe
(i used the autometer ultralite series)
simply locate where your vac lines run under the hood
on my 96 4.0 i installed a "T" compression fitting on the vac line that runs between the back of the valve cover and the intake manifold.
if you have never used compression fittings before--just read the instructions--its pretty simple
