- MilkyWay Galaxy
Well I found some data on the 1997 temperature sensor in the thermostat housing.
11, 370 to 13,600 ohms at 68 F (they list a min/max acceptable value!)
1630 to 1870 ohms at 158 F
640 to 720 ohms at 212 F
The air temperature sensor in the intake manifold hase the same values.
So now the question I have is why does the fan come on when you disconnect the temperature sensor? Perhaps the computer recognizes the sensor is disconected and by default turns on the fan as a failsafe step?
I am still loking for data on the sensor at the rear on top of the engine valve body.
My think is that since pulling the connection to the sensor at the thermostat housing turns on the elctric fan, it must be the sensor that the computer uses to decide when to turn on the electric fan.
It looks like the 97 manual (I am not sure is this beast over 1700 bloddy pages it):banghead:shows only that one sensor running the gauge, fan and giving the PCM data it needs to calculate the A?F ratio, and the 96 was the model year that changed, 96's are suppose to be like 97s. Is that the OEM engine in that 96 jeep? Is it an older head perhaps? Just out of curiousity why not pull the connector to the rear sensor and see what the gauge does, and then do the same on the front sensor and see what the gauge does.
The 97 fsm does say the fan is turned on by the PCM through a relay at
217 F, and turns off at 208 F.
