wavingpine11
- Central PA
Wildmatt said:Sounds good! If all else fails you can pull the trans cooler line off the rad and drain some fluid out that way. Overfilled is just as bad as underfilled. How over is it?
When in AWD, the jeep can still be a one tire fire, IE if one tire slips on one axle the other 3 stop, hence the ability to spin one tire. The tractive force is a lot higher with all 4 tires being powered compared to just 2 though. In 4x4 HI the rotation of front and rear driveshafts are locked together so you would have to spin one front tire and one rear tire.
If you are seriosuly getting wheelspin in full time 4x4, I would buy new tires, athough with the history of this rig it might just be your trans slipping
It has new-ish but ultra-cheap no-brand tires on it now, but I'll be switching them out for the BFG 235/75/15 AT's that are on my 92 this coming weekend, since that's off the road with power steering and clutch release issues for the winter. Wish I had a garage. . .
