CanMan
- Lake Tapps, WA
CanMan said:
Me too, until I was under there, cursing. I think it is a common misconception.tomcat said:no kidding, pardon my ignorance, I thought they would drop right in without pulling the carrier
Daedalus454 said:Will they go in without pulling the carrier if installed in a D35 or 8.25?
goodburbon said:and my wifes 30
and my bro in laws 30
Yes, you have to pull the carrier out, pull the ring gear, install the lunchbox, then zip it all back up tight.
fizassist said:That's why God created Dremels. Grind a hair off a tooth or two, and you're good to go! For properly set up gears, you'll never even get close to the primary contact surface. If you're really anal, you can grind an equal amount off the other side of the ring to balance the weight.
goodburbon said:You are not changing the position of anything, nor are you removing or adding any shims. If done properly you will be very very close. The ones I have done have not made noise or broken yet. Grinding the ring gear while it is still in the housing is a great way to introduce lots of shiny new abrasive into the diff. doing it twice= twice the crap you have to make sure you get out of there.
Oh, and if you're anal enough to remove material from gear teeth that don't need it for "balance" you need some serious mental help.
gijosiahh said:haha well how does it unlock? if you look at it there are the pins and springs and it doesnt seem like both sides of the locker would be able to spin independently.
xjtrailrider said:Even if you grind the ring gear you still need to get the cold rolled pin out of the centershaft, That ring gear has to be moved to get that done!
