Just curious if you can make 95 xj shift sooner ive got the TV cable pulled as tight as possible off the TB, any mods you can do to change or make it shift sooner. obd1
The cable controls fluid pressure only so you're only changing how firm the trans shifts (less firm if you've tightened up the cable). All shifting is done electronically via TCU.
I am too very interested in this, used to have a 88 5 speed and regret getting this 95 XJ with the AW4. So from what you have, can I drive it as a manual when I want to?
If I do not shift will it shift automatically? Sorry if it sounds silly...
