When shooting with a IR gun, try to focus on the heater core outlet, it's the only thing that flows all the time(on late model jeeps). It's basically impossible to know when the t-stat is open and by how much. Shooting hoses is a joke since rubber is a semi-insulator, with a all AL rad shoot the tanks.
Thats what the separate hole in the head at the t-stat housing does.
Mine was doing the same thing. Put in a 180 thermostat, aftermarket temp switch and made the secondary fan kick on @ 170. I also put some vents in the hood to get built up heat out. No problems since. I'm pushing around 35s in 95+ heat with AC on.
On another forum everyone is telling me that I should go back to the original clutch fan with electric fan set up. Is anyone running the electric fan set up that's not having issues?
My Griffin(wide 1 row core) came set-up for only 2 fans but they are advertised as a higher cfm. I still used and prefer the stock redundantcy!
For 16yrs it ran at 210* and now it runs at 205*.
Yeah, I didn't need that shroud but they sent one anyway. I'm using a all factory mech/elec system. This is still working better under extreme loads(I tow a 3K trailer) without the rise in temps,it's hot here!
I don't know what G05 means in your first post or how long you had the champion & 2 fan setup before problems arose, but I had two champion american eagle 2 big row radiators fail at the end tanks where they weren't properly welded. Both failed and started steaming, then spraying in less than a year. Champion is garbage.
