I didnt think I had to spell it out for you...
I don't see any reason that this thread should still be open...
Ok, so far I have...
"219 CI vs. 242 on the Jeep"
-Ok, so CI's affect how the motor sounds... who woulda thought of that one?
"A Porsche motor, GT3 included, is a flat 6"
-True, but there are plenty of "v" arranged supercars with the same sound.
Doesn't say much.
"If you ask me, they sound different because of the exhaust ports, valve configuration, valve lift and duration, exhaust layout etc..."
-I'm looking for somethin a LITTLE bit more conclusive than "if you ask me"
"Port size and shape play a role as does the exhaust system"
-That on the right track, however, I'm still looking for references and/or empirical, more comprehensive data.
"There's so many variables, valve size/layout, displacement, compression ratio, layout, engine block material (yes it makes a difference), cylinder head port sizes. That doesn't even take into account header design, pipe diameter and length"
-That basically reiterates my question. Still looking for some empirical data.
"minute changes in your camshaft/shafts"
-Again, good and true info, but no specific info.
I want to make clear that in no way shape or form am I ridiculing those above who have tried to provide insight! The bottom line is that these people have actually tried do HELP me, not just post in order to act like a tool like igotanxj.
