Dude your on crack :roflmao:
First you say if your not doing major inclines, then go on to say that if its for a "serious rock crawler" its superior. I dont know what kinda Serious rock crawler you think you've seen, but if its not seeing 30-45deg angles then its not serious. And if it is seeing those angles then Even with off road floats, Jet Tubes and the such, your still going to get fuel starvation.
I see it every time I see a toy or CJ thats carb. out at a local event (Truckhaven). The crevases just kill'em with the angles and thats just sand and hard dirt.
Carb Sucks! I would take a 4cyl FI over a 360 carb motor any day! Now if you ahve the $ and means to move from carb to propane or FI then its a different story.
And as for "torque from an AMC V8 is far superior to any other SB V8" again your smoking crack! If you want to compare. Show me a reliabe Mediocore build in a AMC 401 that gets 420ft/lbs on 87oct or a streetable build with over 500ft/lbs on mild race gas? You can get that with a SBC all day! Torque is mostly influenced by Rod length and stroke, both of which you can match between the SBC and a full (true) race build say 430 AMC.
So to say superior is a joke. Both can be built to obtain the same type of numbers, only the SBC will do it for about 1/3 less $. And last longer typically due to more reserch and devel. being done on them and the related go fast parts that people put on them, in the aftermarket arena.
You ever weighed a 360? Its a PIG!
Nothing against a nice 360. But I will say I am a bit bias seeing as we just pulled a mild RV built 360 from a 78CJ and currently have a complete ramjet 350 from GM performance parts on order to replace it.
