collegeoffroad
- Charlottesville, VA
1989 XJ Ltd.
Measures 12v at the battery(and on the gauge) and dips when i put on the brights, and heat. After giving it some gas, the voltage does not return to 12v and also never gets to the 14-15v that it probably should be running...
we just finished replacing the alternator and tested what we thought were the fusible links for shorts, however I"m not sure we even tested the right thing. So what I need to know is a few things...
1.) ANy ideas?
2.) Where are the fusible links? In the hanes manual, it shows a fuse box, whereas online here, I found the FSM and it shows fusible links...don't know which one to believe!
TIA for the help guys! :wave:
1.) ANy ideas?
