Khary23
- Brooklyn, NY and Worcester, MA
My airbag light was on and my horn stopped working so I replaced the clock spring, but the problem persists. Does this mean that I need a new airbag module?
Thanks
Thanks
Thanks
What was/is the status of the replacement clockspring? New, used (junkyard), Evilbay?
What data did you use when replacing the clockspring? FSM?
What's the status of your ignition switch? My airbag like will stay on sometimes until I "jiggle" the switch a little....
Double checked the wiring and every thing is properly connected. I will borrow a multi meter from school and check that there is current. I need to find another steering column for parts before I can put this one back together.
I just put in an airbag and still no horn and the airbag light is still on. I am at a loss.
What airbag? Airbag Control Module?
Replaced the drivers side air bag
My 98 had issues with airbag light and check engine light on intermittently. Determined there was a factory recall for air bag control module . Took to dealer and they replaced it no charge . Fixed all my electrical gremlins for the time being anyway. BTW I requested the build sheet from Jeep that how I found out there was a recall that wasn't performed.
