cherokee Wheeler10
- El Dorado hills
so do you all recommend bying the co2 tanks and what size with 33x12.5 tires ?????
I run a 10# co2 tank with OBA as a backup. I had 33s with this tank and it lasts a long time.cherokee Wheeler10 said:so do you all recommend bying the co2 tanks and what size with 33x12.5 tires ?????
It costs me $11 at a fire extinguisher shop to have my 10# tank filled. and a soda co2 tank will work just the same, but you need to consider getting a handle/regulator guard because if that reg. is knocked off somehow, well.....junkxj said:About how much does it cost to get the 5 gallon filled at a fire extinguesher refill shop?
XJ_ranger said:a 9oz CO2 tank cost $1 to be filled at a painball arena i played at back in CA, however everyone there ran compresses air, becuase it DIDNT fluxuate as much with temperature changes. From my painball expierence, i would never put CO@ in tires, because as it heats up it expands a lot more than air does (in teh case of paintball speed it does)
but that is just paintball and im a stupid newb who doesnt know anything
also it costs $40 to get a fireextinguisher filled last time i did it, that was ABC tho... just for reference...
hey dan, i went to weld shop to get a less expensive set-up, but you went from a less expensive to 400$ set up. why? is the powertank better for some reason?Dan Turner said:No one even mentioned a regulator until the last post. I came onto this thread late. I used a 10 lb tank from beverage factory, got a fixed 125psi regulator from Williams Helium and Balloon supply in Santa Maria, CA for like $35.00. Got a nylon coiled airhose from the Depot. Until I bought teh Powertank mount, I had like $130 invested. I don't have any gauges but you can tell when it's getting empty. It will weigh 10 lbs less.
Dan
XJ NORM said:hey dan, i went to weld shop to get a less expensive set-up, but you went from a less expensive to 400$ set up. why? is the powertank better for some reason?
