I’m the OP, Just going to add to this thread.
So I went with the iro hack n tap. Went pretty smoothly. Ordered a Chinese front driveshaft, and cut it 3/4 of an inch longer then the iro directions said, per a suggestion in this thread. Had to cut off some of the yoke to make fit, but worked out ok.
Now I need to some help on the degree shims I need. My driveshaft angle is 17*, and the pinion angle is 8*. What degree shim should I order?
And is there an easy way to add the shims once the lift is on? I just snuggled down the u bolts, have not torqued them yet.
Thanks.
Since everyone likes pictures, some before and some “in progress” shots.
