- Torrance, CA
The next scheduled workday is Sunday, October 11 on 2N49. The main focus is clearing the construction debris dumped on the trail. Once we've cleared that, pending time, we will continue on the trail brushing the trail as needed.
Map of 2N49
SUNDAY, OCTOBER 11
Meet Point 9:00 AM 2N49 SOUTHERN END (end of Palm Ave. in San Bernardino)
We will meet at 9:00 AM at the Southern terminus of 2N49 with departure to follow. Time permitting we will continue through the entirety of 2N49 existing at the Northern end near Lake Silverwood. If we run out of time on the debris cleanup job we will turn around and exit the same way we came in.
COMMUNICATIONS
CB Radio: The fours. We'll start on 4, if busy we'll bump up to 14, 24, or 34.
2m: 146.585 Simplex
What do I need?
Any vehicle that can do a USFS-rated moderate trail (Stock XJ, okay. 2WD okay with tow points).
Bring gloves, a hat, and loppers. Please bring light long sleeve shirts for brush work. Closed toe shoe mandatory. If you are sensitive to dust you may went to bring a mask to use while we're clearing debris.
Please RSVP if you plan to attend so I can plan.
Thank you for your time and I look forward to seeing you on the 11th.
Map of 2N49
SUNDAY, OCTOBER 11
COMMUNICATIONS
2m: 146.585 Simplex
What do I need?
