adjustable control arms?
low'n'go xj
Oregon City, OR
Just aligned the front end and picked up some RC adjustable control arms. Will installing these arms change my alignment? Also with 4.5" lift does anyone know what I should adjust to for measurement?
Thanks for the Info, now if I follow the measurements I should be ok for a bit till I get the caster set. I have already got the toe set. Would like these on for Saturday.
If the adj arms are set to the same length as where your current ones are, then should not change.
