Rick Anderson
- Lusby, MD
In a FWD car, where the torque reaction from the motor will not lift one wheel and change traction between the two wheels, with an Open differential, I have laid a pair of tire tracks for a good 10 ft. Eventually the tire traction will differ and the open diff, only one tire continues to spin and one of the tracks will typically be a few feet longer than the other.
Remember, with most RWD, the torque reaction with the drivetrain will tend to lift one wheel slightly and vary traction, thus you almost always get a sole tire track during a burn out.
Correct me if I'm wrong on these rudimentary observations and understanding.
An open differential
*Allows the wheels on the axle to spin at different speeds, with no resistance (other than a small amount of friction).
*It CAN transfer power to BOTH wheels or only ONE wheel.
*It does NOT bias the power that goes to any wheel.
*If the wheels are spinning at the same speed, with the same traction, (the differential part is not working, i.e. the spider gears are not turning at all) both wheels will get equal power. Both paths of resistance are equal, thus there is no bias toward either path.
*If the wheels are spinning at different speeds or have different traction, (the differential part is working, i.e. the spider gears are turning) the power will bias toward the "path of least resistance".
A limited slip differential (clutch or cone type)
*Allows the wheels on the axle to spin at different speeds, but with resistance from the clutch/cones.
*It WILL transfer power to BOTH wheels, NEVER only ONE wheel.
*It does NOT bias the power that goes to any wheel, but the clutches/cones prevent all power going to only ONE wheel.
*If the wheels are spinning at the same speed, with the same traction, (the differential part is not working, i.e. the spider gears or clutches/cones are not turning at all) both wheels will get equal power.
*If the wheels are spinning at different speeds or have different traction, (the differential part is working, i.e. the spider gears and clutches/cones are turning) the power will take the "path of least resistance" BUT, the resistance of the Clutch/Cones will limit the amount of difference in speed of the wheels and thus force power to thru the other path as well. It clutches doesn't really bias the power toward the higher traction/slower spinning wheel, it just keeps the lower traction/faster spinning wheel wheel from taking up all the power.
A locker:
*Does NOT allow the wheels on the axle to spin at different speeds.
*It WILL transfer power to BOTH wheels.
*It does NOT bias the power that goes to any wheel, both wheel will receive equal power, because there is no alternative path for it to go.
*The wheels can ONLY spin at the SAME SPEED, if turns or traction require the wheels to spin at different speeds the tires have to slip (break traction) or break the drivetrain.
*Since there is NO difference in wheel speed, then the effect is reversed, the drive train is forced to create a difference in traction to keep the power even, thus the tire required to spin faster will break traction.
A Torsen LSD:
*Allows the wheels on the axle to spin at different speeds, with little resistance (perhaps additional friction from more and bigger gears involved).
*It WILL transfer power to BOTH wheels, and rare cases ONE wheel (although most also have clutches to prevent only one wheel getting power).
*It does BIAS the power that goes to the wheels toward the higher traction wheel, the gears are preloaded to reverse the path of the power. In rare cases, like one wheel with absolutely zero traction (like the wheel lifts in the air) the toque BIAS will not work. There are clutches included in a lot Torsen LSD to cover this scenario and still keep both wheels turning.
*If the wheels are spinning at the same speed, with the same traction, (the differential part is not working, i.e. the bias gears are not turning at all) both wheels will get equal power.
*If the wheels are spinning at different speeds or have different traction, (the differential part is working, i.e. the bias gears are turning and the pre-load of the gears forces the power in the opposite direction) the power will take the "path of greater resistance" and most of the power will go to the higher traction/slower spinning wheel.
There are even more types of differentials, using things like fluid coupling, etc.
Just when you head is starting to hurt, you have remember, that there has to be a differential between both front and rear axles as well. (Someone correct me if I'm wrong on the following).
AWD - Open type differential, that allows front/rear axles to spin at different speeds with no bias.
Full Time 4WD - Limited Slip type differential, that allows front/rear axles to spin at different speeds but limits the amount of difference, so NOT all the power can go toward one axle.
Part Time 4WD - Locker type differential, that forces both front/rear axles to spin at the same speed.
I think there are some AWD/Full Time 4WD setup with the sophisticated LSD's that bias power toward one axle over the other, etc.
A locker:
A Torsen LSD:
