colorado99xj
- littleton, co
Time has come to put my Jeep up for sale. Car has 180k on I am second owner, had it since 2001 and 32k miles. Took Jeep off the road shortly after $3k of work was done as motor issues arose, great start for trail rig or even daily driver with some work.
$1500 or make an offer, car is sold as is and is located in Littleton.
The bad:
Does not run, has not been driven in awhile
Knocking from engine
Drivers side doors (front and rear) are inoperable due to broken door hinges (front window inoperable as well)
Tailgate / bumper damage
Some rust spots / body damage
Original factory wheels / tires (3 stock tires, one 30 x9.5 on stock wheel)
The good:
3.5" Rubicon Express Lift (Full Springs Front and Rear, Sway Bar Disconnects)
Bilstein Shocks
Slip yoke eliminator / custom rear driveshaft
New Tailgate (not on)
full interior in good shape
Recently Replaced before taking off the road:
Power Steering - Pump, hoses, pulley, fluid
Serpentine Belt
Full Radiator and Hoses, fluid
Motor Mounts (Rustys)
Front ball joints -- upper, lower
Adjustable Trac bar
Tie Rod Ends
U-Joints -- Rear Drive shaft, front axles shafts
Wheel Bearings / Hub Assembly (Timken)
Front Brakes (pad, rotors, fluid)
Rear Brakes -- shoes, springs, rebuild
Tcase / Transmission Fluid
Diff Fluid -- front, rear
Other Items
Full mechanics manual included (Hayes)
Aftermarket radio, alarm
XJ, Cherokee, Jeep, trail rig, parts, mechanic
Let me know if you have any interest (please text first, then call)
720-296-7244
https://denver.craigslist.org/cto/6072122909.html
The bad:
The good:
Bilstein Shocks
Serpentine Belt
Adjustable Trac bar
Tie Rod Ends
Other Items
720-296-7244
