scotttruhart
- las vegas
Today when using the one touch open window feature , my window went down fully then i heard some gear grinding noises untill i pushed the switch upwards, also the door trim buckled . i took the door skin off and operated the unit and the window seems to work normal untill it bottoms out. it seems that the motor is not seeing that the window is all the way down and keeps on running motor, as a result the cable assembly sort of binds upwards and pops out rubber window sill . i see no track problems , is there a limit swith in the motor? from what i have seen here in forums thsi is common issue with the 99. any suggestions or do i just need to replace the regulator motor package. any one know of a aftermarket place to get a new one. dealer gets 120$ for the part.
