Can't believe that I haven't posted this on naxja...haven't started any threads in 2 years almost, other than a couple of classifieds.
Anywho...here we go. Picked this up on May 22nd, 2011
1999 cherokee classic
TWO DOOR!
factory CD/tape deck
a/c
power windows
power locks
tilt
cruise
keyless entry
fog lamps
front and rear tow hooks
factory skid package (front, tcase, gas tank)
up-country coil package (1" over stock, no rear sway bar)
color match trim package
4.0
5 SPEED!
jeep has 250,000 miles on it, and driver's floor rot
engine has a wrist pin knock (I've isolated it down to wrist pin, number 4 or 5, once I got the hood open....special thanks to PeteM on that one!)
solution...i'm building a stroker for my '87 comanche, and this motor will be the base for the stroker. going to put my .030 bore mopar reman with 2001 intake, 62mm Tb, neon srt4 injectors, borla header in this jeep, and build the motor up for my other one.
best part...I purchased it from the original owner. came with the window sticker, purchase reciept, build specs, all repair reciepts, etc.
anyways, pics. need it done by the weekend...crown vic is about to lose it's trans, so it's gotta go.
little bit of rust clean up and repair, it will be a fun little DD.
-Pat
TWO DOOR!
a/c
power windows
power locks
tilt
cruise
keyless entry
fog lamps
4.0
5 SPEED!
-Pat
