I searched with some success however just have a few additional questions.
My XJ has developed the annoying habit ot locking and unlocking by itself as I drive. Most of the time when I press the lock button the locks dont function the switch only clicks but the actuators do not ingage, something sounds jammed. Also when someone opens the passenger side door the lock clicks. For this reason I figure its an issue with the passenger side door. I ripped it apart and pulled out the mechanism, everything looks good(wiring, linkage) I cleaned it up and lubed all moving parts. As soon as I plugged the 2 switches (window, lock) into the wiring harness the switch clicked even without the actuator connected. I tried to lock and unlock the doors with both the driver and passenger switch, but no luck it still sounds like something is jammed. Does this mean theres an issue with the switch panel?
