Forestgnome
- Sacto, CA
Hi All,
I know this problem has been addressed many times, but my question is slightly different. Mine is a 5.2L. It began stalling when stopping in drive. It always starts back up, but won't idle, which requires me to modulate the throttle to keep it running. It's very intermittant, so it's hard to troubleshoot. I know by other posts that common problems are IAC and crank sensor. My question is, what problems that cause stalling also do not register trouble codes? Seems to me if the crank sensor was failing, you'ld get an idle speed sensor code, right? There's also a code for the IAC, but of course would only register if the solenoid part failed. I do get a repeating intermittant code, but it's for the evap system test.
