RudiXJ
- Orlando FL
I'm new to the forums, is amazing how much info. are in this forums.
I have a few questions about my very clean and reliable 143,000 96xj 2dr. 4x4. She is my weekend warrior. Tow my flats boat, rescue vehicle, beaches, and to keep the miles off the Infinity. Well, It finally left me on the side of the road with a blown head gasket and clogged radiator. I decided is time to do some mods and put a little more muscle in her. I also had a RMS to R&R..I had a little $ laying around and purchased a CSF 3 core Rad., flowkooler W. pump, oil pump and some power upgrades. Clifford 264 EFI cam kit 206 @ .50 .474 lift, JP Double roller T. chain, and a Performance head from Clearwater Heads, big valves 2.02 in-1.60 ex. 0331 new casting. Clearwater built the head specifically for this cam. The head wasn't cheap. I found out that my old 0630 head was not cracked or warped, but at least I got to keep it.
Currently the XJ has a Magnaflow CAT back, K&N CAI and D.U.I Performance ignition kit.
My questions are:
1. Headers? hi-flow CAT? or keep the factory Ex. man. since is not cracked.
2. I picked up a 99 xj In. manifold from the salvage. ($10) Use it, or keep the old one??
3. 703 injectors? $100 from Precision Injectors, they are local. Purchase or keep the old injectors?
4. HP/TQ predictions?? Hopefully I will have a nice power gain.
BTW, the Cam Kit, RMS, JP Chain are installed at this time. Everything looked great ( cam. bearings, no sludge, rear main bearing) etc. after so many miles I was impressed. The only thing was the carbon buildup in the intake runners and top of pistons. Everything bolted up great so far.
Thanks
My questions are:
Thanks
