so just tried to turn it over and now the battery is low again... i will try with a jump next.
so to this point here is where i am:
1. fuses in engine bay checked and OK'd with voltmeter
2. relays switched around as well
3. crank sensor replaced even though it was within spec
4. ignition coil within resistance specs
5. all grounds refreshed and battery connections as well
6. TPS within spec
7. getting good fuel spray from schrader
8. rotor is turning and i seem to have good spark (blue snappy spark)
9. pulled and checked plugs, they are in good shape, but a little wet, still fired upon testing
10. before all of the above, had adv auto test the battery which was good.
11. fuel injectors are clicking while turning over, so that should pretty much rule out CPS and camshaft sensor (right?)
12. it will not start with starter fluid
even though it tested good, could my battery still be bad? I am not excited to spend 100$ on a new battery just to find out that isn't it. wouldn't it start with a jump even if the battery was bad???
really pulling my hair out here
what are your thoughts?
