So my XJ just randomly started doing this again. Randomly it will start to idle high (1500-2000) and smell very rich. When it does this it will, more often than not, stall out when trying to pull away from a stop. It seems like it's completely flooding the motor out. To get it fired up again I have to 'flood' start it. Once it fires it runs extremely rough and pours black smoke then it will clear up and run smooth. Last time I had a high idle problem the TPS was the culprit, so I swapped it and the IAC without seeming to fix the problem.
The MAP is relatively new and nothing else seems obviously wrong.
Any ideas?
Any ideas?
