Black Squirrel
- Around
Hello, I have a 1991 Cherokee and the electric fan is not working.
So far I have tested:
A/C on - no fan
Disconnect temp sensor at t-stat housing - no fan
Swap relays - no fan
Jump pin 30 of the relay to 87 - fan comes on
Pin 30 - B+
Pin 85 - B+
Pin 86 - shows connectivity to ground when the fan should be on
Relay clicks then installing
If I add a small gauge jumper wire from pin 86 to ground with the relay installed - fan comes on
I am kind of lost, the only thing that I can think of that I didn't have time to check yet is a partial open in the wire from the ECM to pin 86 of the relay, but not enough for the meter to see.
Any advise would be greatly appreciated!
A/C on - no fan
Pin 30 - B+
Pin 85 - B+
